How to update Asset object attribute using automation with values from associated Jira issue
プラットフォームについて: Cloud のみ - この記事は、 クラウド プラットフォームのアトラシアン製品にのみ適用されます。
要約
This article details steps to automatically update the Attributes for an Asset object with values from the associated Jira issue via Automation for Jira. This action also can be of benefit to non-JSM licensed users to edit objects in Assets via creating an issue in Jira or the Customer Portal.
環境
Jira Service Management Assets
シナリオ
The admin would like to update an Attribute of assets selected on an Asset object field in JSM issues. For example, the admin would like to update the 'Owner' Attribute of a 'Computer' asset with the Reporter of the JSM issue.
ソリューション
- Create Object Schema and Object type for Assets.
- In the Assets object type, add 'Owner' attribute.
- Create Asset object custom field and add to JSM screen. E.g: Computer
- Then, create automation as below:-
- Pick Issue Created trigger (Or any trigger depending on when/where in the issue you would like the attribute to be updated)
Then, add the 'Edit Assets field attributes' action.
The 'Edit Assets field attributes' action is located under Issue Actions
- For Asset Field, select the Asset object field created on Step 3.
- Choose the attributes that you would like to update. For example, to update the Owner attribute with the Reporter of the Jira issue:
- Save and publish the automation rule.
- Lastly, the moment of truth. Test it
This automation also can be used to update object attributes with other smart values or fixed text as well. E.g: value from a different custom field in the issue. Feel free to explore the smart values that can be used on the Advance your rules with smart values documentation page.
The same actions are not available on Jira Server/Data Center. More details and a potential workaround can be found here:
